Tormek T-8 Original
Tormek T-8 Original
Spain · 230V
€878,00
Sale price  €878,00 Regular price
Tormek T-8 Original
Tormek T-8 Original
€878,00
VersionSpain · 230V
270 × 270 × 330 mm
393 × 296 × 383 mm
14.8 kg
18.7 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
Spain · 230V
Article no.: T-8 ORIG/ES
Instruction Manual
View
Sign up
