EM-15 Edge Marker
EM-15 Edge Marker
£4.00
Sale price  £4.00 Regular price
EM-15 Edge Marker
The Tormek marker method
  1. Color the bevel, mount your tool in the jig and place it on the universal support with the bevel resting on the grinding wheel.
  2. Turn the grinding wheel forward with your hand and check where on the bevel the color is rubbed off.
  3. Raise or lower the universal support until the color disappears over the entire width of the bevel. The angle is now correct and it's time to start sharpening!
EM-15 Edge Marker
£4.00
20 g
