Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
£47.00
SE-77 Square Edge Jig
£67.00
AX-40 Axe Jig
£41.00
£235.00
RB-180 Rotating Base
£54.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
