For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- UK · 230V
- Article no.: T-1 GRA/GB
- UK · 230V
- Article no.: T-1 BLO/GB
- UK · 230V
- Article no.: T-1 ALO/GB
- UK · 230V
- Article no.: T-1 REB/GB
£49.00
£130.00
£116.00
£80.00
£16.50
KPP-2 Knife Protection Pads
£5.30
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
