Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
5,200 kr
SE-77 Square Edge Jig
7,400 kr
AX-40 Axe Jig
4,600 kr
24,300 kr
RB-180 Rotating Base
6,000 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
