For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
¥5,600
¥14,800
¥13,800
¥9,400
¥1,660
KPP-2 Knife Protection Pads
¥625
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
