For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Japan · 115V
- Article no.: T-2 PRO/JP
¥25,300
¥27,300
DWC-200 Diamond Wheel Coarse
¥27,300
SC-60 Scissors Jig
¥7,000
¥20,000
¥1,660
KPP-2 Knife Protection Pads
¥625
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
