Tormek T-8 Original
Tormek T-8 Original
Japan · 115V
Tormek T-8 Original
Tormek T-8 Original
270 × 270 × 330 mm
393 × 296 × 383 mm
14.8 kg
18.7 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
Instruction Manual
View
Sign up
