For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
- Width: 8" (204 mm)
- Depth: 7 ¾" (196 mm)
- Height: 7 ⅛" (181 mm)
Cord
- Cord length: 5.5 ft (1.7 m)
Grinding Wheel
- Speed: Maximum 200 rpm
- Single-phase AC motor
- Frequency: 50–60 Hz
537,29 kr
1.197,63 kr
1.115,91 kr
886,72 kr
139,96 kr
KPP-2 Knife Protection Pads
55,42 kr
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
