Tormek T-8 Custom
Tormek T-8 Custom
Scandinavia · 230V
Tormek T-8 Custom
Tormek T-8 Custom
  • Add the appropriate jigs to sharpen different edge tools.
  • Choose the grinding wheel and honing wheel to build a customized sharpening system.
270 × 270 × 286 mm
388 × 298 × 325 mm
9.3 kg
11.35 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
Instruction Manual
View
HB-10 Tormek Handbook comes in several language versions depending on the market
Sign up
Choose Your Grinding Wheel
Choose Your Honing Wheel
