Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
- Scandinavia · 230V
- Article no.: T-4 BLACK/SCAND
Sharpening Jigs and Accessories
506,29 kr
SE-77 Square Edge Jig
710,13 kr
AX-40 Axe Jig
446,18 kr
2.413,11 kr
KSK-106 Knife Sharpening Kit
3.073,45 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
