Diamond Wheel Coarse
200 mm
With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DC-200 Diamond Wheel Coarse fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
DC-200 Diamond Wheel Coarse does not leave a fine finish, but should be followed by sharpening with a more fine grained grinding wheel, such as the DF-200 Diamond Wheel Fine or the DE-200 Diamond Wheel Extra Fine.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
Size
The Diamond Wheel Coarse is designed to provide effective sharpening and rapid repair of a dull or damaged edge. The diamond wheel has a grit size of 360 for fast steel removal and is particularly useful for tool shaping.
  • Sharpens all types of steel and ceramic.
  • Side sharpening makes it possible to create a flat bevel.
  • Coarse grit for fast steel removal, repair and reshaping.
  • Durable diamond abrasive.
  • Maintains a constant shape and diameter.
3.18 kg
1 bottle of ACC-150 Anti-Corrosion Concentrate that makes the water corrosion inhibitant
