For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Article no.: T-2 PRO/EUR
R$ 253,00
R$ 273,00
DWC-200 Diamond Wheel Coarse
R$ 273,00
SC-60 Scissors Jig
R$ 70,00
R$ 200,00
R$ 16,60
KPP-2 Knife Protection Pads
R$ 6,25
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
