AWT-250 Water Trough for T-7
Magnet traps steel particles
The AWT-250 Advanced Water Trough for T-7 has a built-in magnet that effectively traps steel particles while you're sharpening, keeping your grindstone cleaner and allowing it to cut more freely. These particles can otherwise be pressed into the surface layer of the stone and impair its abrasive properties. The steel particles are all collected at the magnet when you empty the water trough. It's easy to clean with a paper towel.
Drip cover for long tools
There's an extra drip cover for the really long tools that extend over the edge of the frame (such as long knives and planer blades). It's easy to fit on the edge and channels the water back to the trough. This will keep your sharpening cleaner.
The AWT-250 Advanced Water Trough for T-7 fits the Tormek T-7, Tormek 2000 and older models with a 250 mm (9 7/8") grinding wheel.
The AWT-250 Water Trough for T-7 has a greatly extended frame to keep your workbench free of water. It also comes with a built-in magnet that effectively traps steel particles while you sharpen and allows you to clean them off when you're done. A removable drip cover for long tools is also included.
  • Easy to mount.
  • Fits Tormek T-7, Tormek 2000 and older models with a 250 mm grinding wheel.
  • Drip cover helps manage water when sharpening long tools.
  • Built-in magnet captures steel particles.
530 g
Black
Plastic
