Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
R$ 52,00
SE-77 Square Edge Jig
R$ 74,00
AX-40 Axe Jig
R$ 46,00
R$ 243,00
RB-180 Rotating Base
R$ 60,00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
