For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
R$ 56,00
R$ 148,00
R$ 138,00
R$ 94,00
R$ 16,60
KPP-2 Knife Protection Pads
R$ 6,25
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
