Tormek T-8 Custom
- Add the appropriate jigs to sharpen different edge tools.
- Choose the grinding wheel and honing wheel to build a customized sharpening system.
270 × 270 × 286 mm
388 × 298 × 325 mm
9.3 kg
11.5 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
- Netherlands · 230V
- Article no.: T-8 CUST/NL
Choose Your Grinding Wheel
Choose Your Honing Wheel
