Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
€52,00
€74,00
AX-40 Vorrichtung für Äxte
€46,00
€243,00
RB-180 Drehscheibe
€60,00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
