For home cooks
- Meule diamantée fine.
150 tr/min. Couple 2 Nm.
- Switzerland · 230V
- Article no.: T-1 ALO/CH
- Article no.: T-1 GRA/CH
- Article no.: T-1 BLO/CH
- Article no.: T-1 REB/CH
Spécifications du produit
- Width: 8" (204 mm)
- Depth: 7 ¾" (196 mm)
- Height: 7 ⅛" (181 mm)
Cord
- Cord length: 5.5 ft (1.7 m)
Grinding Wheel
- Speed: Maximum 200 rpm
- Single-phase AC motor
- Frequency: 50–60 Hz
Sign upProfessional Sharpness
Sharpening Your Knives
Composite Honing Wheel
Patented Angle Guide
