For professional chefs
- Réglage rapide et simple.
240 × 210 × 285 mm
7.8 kg
8.6 kg
Argent
140 tr/min. Couple 8.4 Nm.
- Switzerland · 230V
- Article no.: T-2 PRO/CH
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
