DWC-200 Diamond Wheel Coarse
€273,00
Sale price  €273,00 Regular price
Sharpen and repair your kitchen knives
The DWC-200 Diamond Wheel Coarse is a replacement grinding wheel for the Tormek T-2 Pro Kitchen Knife Sharpener. This diamond grinding wheel allows you to sharpen knife blades made of all kinds of different materials, such as steel, carbide and ceramic.
It removes material very efficiently thanks to its coarse 360 grit. It also has a diamond coating on the flat side of the grinding wheel. This is particularly helpful when you have to repair a damaged knife and need to remove a lot of material from the knife.
Best for teamwork
The diamond grinding wheel leaves a rough finish. Hence, we recommend switching to the DWF-200 Diamond Wheel Fine or DWE-200 Diamond Wheel Extra Fine grinding wheels when you've finished removing material if you want a smoother bevel. After sharpening, deburr and polish the new bevel on the PW-160 Conical Composite Honing Wheel.
€273,00
The DWC-200 Diamond Wheel Coarse is a replacement grinding wheel, with a coarser grit, for the Tormek T-2 Pro Kitchen Knife Sharpener. It's ideal if you have damaged knives and want to be able to remove a lot of material quickly to repair the edge. The DWC-200 Diamond Wheel Coarse is 360 grit.
  • Easy to mount.
  • 360 grit.
2.94 kg
Steel, diamond coating
