DBS-22 Drill Bit Sharpening Attachment
€298,00
Sale price  €298,00 Regular price
Four-facet point that lasts longer
The patented DBS-22 Drill Bit Sharpening Attachment is used to create a four-facet point that provides great cutting characteristics as the cross-cut of the drill bit is pointed instead of being almost flat, as on many other drill bits. A four-facet point won't wander and requires significantly less drilling pressure compared to a conventional cone point drill.
A precision-sharpened four-facet point also reduces heat build-up, giving a very long service life for the drill bit. Independent tests show that drill bits sharpened using Tormek equipment last more than four times longer than new conventional drill bits¹.
¹ Uddeholm Tooling AB, 2010. In the test, 15 mm (0.59") deep holes were drilled in a hardened steel using a 6 mm (0.24") drill bit. At a speed of 1326 rpm and 0.15 mm (0.006") feed per revolution, the drill bits sharpened using the Tormek equipment lasted for 327 holes on average, while the new S-tip drill bits lasted for 72 holes.
Controlled sharpening
The risk of overheating and microcracking or loss of hardening of the steel is eliminated by working with the natural laws and cooling the edge continuously. You have full control at all times and can see how sharpening is progressing. A magnifying glass is included for smaller drill bits to help you line up the bit in the jig and see the results of your sharpening.
The hole where you attach the base plate to the universal support has a special wedge shape which increases the locking force by as much as 250% compared to a round hole. You can lock the base plate instantly at the selected angle. This ingenious design is an original Tormek innovation commonly known as the TorLock.
€298,00
The DBS-22 Drill Bit Sharpening Attachment allows you to sharpen your drill bits from 3 mm (1/8") to 22 mm (7/8") in diameter with maximum precision and to give a four-facet point for best performance. The optimum tip and lip relief angle can be set for each drilling operation, taking into account the drill bit size and material. You can also sharpen broken bits back to the perfect shape.
  • Tormek cites testing showing more than four times longer drill-bit life than a conventional S-point.
  • Supports high-precision drill-bit sharpening.
  • Creates a four-facet point for efficient drilling and longer drill-bit life.
  • Best suited to Tormek T-8 and also works with older Tormek models.
3.29 kg
Gray/black
Precision-cast zinc, stainless steel, black composite
Jig setting template with magnets
One tube of Tormek PTFE lubricant
Magnifying glass to line up the drill bit in the jig
