Adapted for your bench grinder
If you already have a Wolverine Vee-Arm External link, opens in new window. mounted on your bench grinder, you can add this converter so as to mount the BGM-100 Bench Grinder Mounting Set directly on the Vee-Arm.
Wolverine is a OneWay Manufacturing External link, opens in new window. product. Tormek is not associated with OneWay in any way. The Wolverine and OneWay brands are both the property of their respective owners.
OWC-1 Tormek Converter
The OWC-1 Tormek Converter is an attachment that makes it possible to use the Tormek jig system directly on a bench grinder with a Wolverine Vee-Arm, together with the BGM-100 Bench Grinder Mounting Set.
- Keep the same jig setting between bench-grinder shaping and Tormek sharpening.
- Easy to use.
- Works with most standard bench grinders fitted with a Wolverine Vee-Arm and suitable grinding wheel.
- Lets you use SVD-186 R Gouge Jig, SVS-50 Multi Jig, SVD-110 Tool Rest and TTS-100 Turning Tool Setter on a bench grinder with a Wolverine Vee-Arm.
- Supports rapid reshaping of tool profiles.
510 g
Gray
Galvanized steel, aluminum, black composite knobs
