Tormek T-4 Bushcraft
- Stainless-steel shaft with EzyLock.
- Water cooling prevents the steel from overheating.
- Supplied with KJ-45 Centering Knife Jig and AX-40 Axe Jig for outdoor tools.
- RKX18 drive system.
- Cast-zinc top with precision mounts.
- Compact water-cooled sharpening system for edge tools.
- Maintenance-free AC motor designed to maintain speed under load.
10.17 kg
Green/gray
140 rpm. Torque 8.4 Nm.
- Article no.: T-4 BUSH-AX/EUR
Sign upDurable Knife Edges
