Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
€52,00
SE-77 Square Edge Jig
€74,00
AX-40 Axe Jig
€46,00
€243,00
RB-180 Rotating Base
€60,00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
