Tormek T-1 Kitchen
Swedish Red / EU · 230V
€400,00
Sale price  €400,00 Regular price
Tormek T-1 Kitchen
€400,00
ColorSwedish Red
VersionEU · 230V
  • Designed for sharpening kitchen knives at home.
  • Patented guide supports a precise sharpening angle.
  • Composite honing wheel with integrated polishing compound.
  • Fine diamond grinding wheel.
  • Powder-coated cast-zinc housing with a wooden handle.
  • Available in several colors.
  • Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
EU · 230V
Article no.: T-1 REB/EUR
EU · 230V
Article no.: T-1 ALO/EUR
EU · 230V
Article no.: T-1 GRA/EUR
EU · 230V
Article no.: T-1 BLO/EUR
  • Width: 8" (204 mm)
  • Depth: 7 ¾" (196 mm)
  • Height: 7 ⅛" (181 mm)
Cord
  • Cord length: 5.5 ft (1.7 m)
Grinding Wheel
  • Speed: Maximum 200 rpm
  • Single-phase AC motor
  • Frequency: 50–60 Hz
Instruction Manual
View
Information card for getting started quick and easy
KPP-2 Knife Protection Pads mounted in the guide
Sign up
Professional Sharpness
Sharpening Your Knives
