Get hooked on extra hooks
The TS-740 Sharpening Station comes equipped with two wheel hooks as standard. With the TSH-50 Grinding Wheel Hook, you can expand your storage capacity and keep two more wheels neatly stored on your sharpening station.
The hooks are easily mounted on the side panels of the TS-740 Sharpening Station and are designed to securely hold Tormek grinding wheels and honing wheels when not in use.
Keep your wheels organized
Having dedicated storage for your wheels helps keep your workspace tidy and makes it easy to switch between different wheel types during sharpening. Whether you use multiple grinding wheels for different materials or grit progression, or want a convenient place to store spare wheels, the TSH-50 Grinding Wheel Hook helps you keep everything close at hand.
TSH-50 Grinding Wheel Hook is a set of two additional hooks for the TS-740 Sharpening Station. Use them to conveniently store two extra grinding wheels or honing wheels, keeping them organized and always within reach.
- Two hooks for storing grinding and honing wheels.
- Also fits standard 9 × 9 mm square holes with 38 mm center-to-center spacing.
- Keeps the sharpening station organized.
- Keeps wheels within easy reach.
- Designed for TS-740 Sharpening Station.
- Quick to install.
130 × 75 × 40 mm
120 g
Gray/black
Galvanized steel, plastic
