CHF 55.00
Sale price  CHF 55.00 Regular price
How to use ACC-150 Anti-Corrosion Concentrate
ACC-150 Anti-Corrosion Concentrate makes the water in your water-cooled sharpening system corrosion inhibitant. It's used when wet sharpening with any of Tormek's diamond grinding wheels. You can also use it with a grindstone without problems, so you don't have to discard it if you want to switch from a diamond grinding wheel to a grindstone, and then back again. Then you'll still have corrosion inhibiting water when you return to your diamond grinding wheel.
Add 10 ml (0.02 pints) of concentrate to 250 ml (0.4 pints) of water (~4%). The bottles come with a measuring scale for easy dosing. Mix the concentrate and water, then pour into the water tray. If you want to save the mixture overnight, remember to always lower or remove the water tray so that your grinding wheel doesn't sit in the water more than necessary. ACC-150 Anti-Corrosion Concentrate doesn't contain antifreeze.
Each pack contains 2 * 150 ml (0.26 pints).
CHF 55.00
ACC-150 Anti-Corrosion Concentrate makes the water corrosion inhibitant and protects your diamond grinding wheels to prevents them from rusting. The anti-corrosion concentrate is always used for wet sharpening with diamond grinding wheels. Anti-corrosion concentrate won't harm your regular grindstones if you have it in the water, so you can keep treated water if you want to switch between a diamond grinding wheel and a grindstone, and then back again.
  • Pack contains two 150 ml bottles.
  • Add to the water when sharpening with diamond grinding wheels to help prevent rust.
  • Can also be used with grindstones to reduce the need to replace the water.
  • Treated water also provides some rust protection for sharpened tools.
390 g
Light Blue
Dodecanedioic acid, water, plastic bottle
2 × 150 ml bottles of ACC-150 Anti-Corrosion Concentrate
