KSK-106 Knife Sharpening Kit
Knife Sharpening Innovation
If anyone knows sharpening, it's us. We have been designing, developing and manufacturing sharpening machines in Sweden for over 50 years. The KSK-106 Knife Sharpening Kit is the complete setup for sharpening knives on your Tormek machine – the original water-cooled sharpening system since 1973. This kit features a collection of all our jigs and accessories for getting a knife way sharper than you would ever need.
Included are no fewer than FIVE patented knife sharpening essentials that have been tried, tested, and improved over the decades.
Sharpen Virtually any Knife
Navigating sharpening methods and accessories can be overwhelming. The KSK-106 Knife Sharpening Kit removes that barrier by including all essential components needed to sharpen most knives – from small everyday carry knives to larger kitchen and outdoor knives.
Every product in the kit is part of the Tormek System and developed to work together for precise angle control, stability, and consistency.
The KJ-45 Centering Knife Jig fits the vast majority of knives. It centers the blade in its jaws for an even sharpening angle by just flipping the knife over. The two stops ensure you can sharpen even the tallest blades, while also allowing a controlled sharpening of convex bevels.
With the included MB-102 Multi Base you can sharpen on the completely flat outside of our diamond grinding wheels to achieve a completely flat bevel. The Multi Base also allows you to sharpen knives edge trailing, as well as controlled deburring, polishing, and honing with jigs on the honing wheel.
The KJ-140 Wide Centering Knife Jig does the same job as its narrower version, but the wider jaws help stabilize longer, flexible blades to ensure a consistent result on, for example, filleting knives.
For knives with blades too small to properly clamp in the KJ-45 Centering Knife Jig we've included the SVM-00 Small Knife Holder. It provides precision sharpening for even the smallest blades.
Maximum Precision, Quick and Easy
The KS-123 Knife Angle Setter has set a new standard for precision in knife sharpening. It lets you set the exact sharpening angle in three easy steps. It is truly a relief to take away all the guesswork from the angle-setting process, and have a reliable, analog solution you can count on. Setting the angle between 8°-25° (degrees per side, dps) takes only a few seconds.
When you are done sharpening you can inspect the bevel, burr, and the final edge with the CU-8 Edge Loupe with 8 x magnification. You can learn a lot by studying the grinding pattern and the burr during various stages of sharpening, ensuring a consistent result.
Secure and Organized Storage
All jigs and accessories included come packaged in the TC-800 Tormek Case together with the KSK-00 Storage Tray for Knife Sharpening Kit. This specially designed packaging makes it easy to store and keep track of your jigs and accessories for sharpening knives at home or in your workshop. A stylish leather handle also makes the case easy to carry around.
The TC-800 Tormek Case is made of a durable plastic material and has a sliding lid that keeps everything in place. It is stackable, so if you have another case, they can be stacked perfectly on top of each other. The storage tray is made of EPP, a material that's highly durable and perfect for storing your jigs for many years to come. It fits perfectly in the case and in the drawers of the TS-740 Sharpening Station.
Turn your water-cooled sharpening system into a knife sharpening powerhouse with the KSK-106 Knife Sharpening Kit. It lets you sharpen virtually any knife with maximum accuracy – edge trailing or edge leading. The kit also enables controlled deburring, honing and polishing using jigs for consistent, repeatable results. This is the ultimate kit for knife sharpening professionals and enthusiasts alike. Efficieny, precision, and versatility – all neatly and securely stored in one place. Designed to make every knife your favorite. Availability may vary during the launch phase.
  • Durable EPP storage tray keeps the equipment organized.
  • Provides the equipment needed to sharpen virtually any knife on the Tormek water-cooled sharpening system.
  • Enables controlled honing, deburring and polishing using jigs.
  • Makes it quick to set an exact sharpening angle.
  • Includes six essential jigs and accessories together with additional items.
  • Supports sharpening with the edge or away from the edge.
  • Supports concave, flat and convex bevels.
  • Convenient to transport in TC-800 Tormek Case.
404 × 309 × 98 mm
2.73 kg
2.99 kg
Dark gray
TC-800 Tormek Case
EM-15 Edge Marker
CU-8 Edge Loupe
MB-102 Multi Base
One pack of five adhesive Tormek bandages
