Diamond Wheel Coarse
200 mm
CHF 286.00
Sale price  CHF 286.00 Regular price
With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DC-200 Diamond Wheel Coarse fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
DC-200 Diamond Wheel Coarse does not leave a fine finish, but should be followed by sharpening with a more fine grained grinding wheel, such as the DF-200 Diamond Wheel Fine or the DE-200 Diamond Wheel Extra Fine.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
CHF 286.00
Size
The Diamond Wheel Coarse is designed to provide effective sharpening and rapid repair of a dull or damaged edge. The diamond wheel has a grit size of 360 for fast steel removal and is particularly useful for tool shaping.
  • Sharpens all types of steel and ceramic.
  • Side sharpening makes it possible to create a flat bevel.
  • Coarse grit for fast steel removal, repair and reshaping.
  • Durable diamond abrasive.
  • Maintains a constant shape and diameter.
3.18 kg
1 bottle of ACC-150 Anti-Corrosion Concentrate that makes the water corrosion inhibitant
