Tormek T-8 Original
- Sharpens a wide range of edge tools using the appropriate Tormek jigs.
270 × 270 × 330 mm
393 × 296 × 383 mm
14.8 kg
18.7 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
- Switzerland · 230V
- Article no.: T-8 ORIG/CH
