Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
CHF 58.00
SE-77 Square Edge Jig
CHF 88.00
AX-40 Axe Jig
CHF 51.00
CHF 369.00
RB-180 Rotating Base
CHF 69.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
