Diamond Wheel Fine
Diamond Wheel Fine
250 mm
CHF 370.00
Sale price  CHF 370.00 Regular price
Diamond Wheel Fine
With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DF-200 Diamond Wheel Fine fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
DF-250 Diamond Wheel Fine
CHF 370.00
Size
Tormek's Diamond Wheel Fine is the ultimate all-round diamond grinding wheel, combining efficient steel removal with a smooth grinding surface. The wheel has a grit size of 600, providing effective sharpening and a smooth surface finish.
  • Sharpens all types of steel and ceramic.
  • Side sharpening makes it possible to create a flat bevel.
  • Efficient steel removal with a smooth finish.
  • Durable diamond abrasive.
  • Maintains a constant shape and diameter.
5.6 kg
1 bottle of ACC-150 Anti-Corrosion Concentrate that makes the water corrosion inhibitant
