CHF 216.00
Sale price  CHF 216.00 Regular price
Sharpens your moulding knives with ease
Since the sharpening is done on the flat backside of the moulding knife, this jig can handle all kinds of profiles with a maximum width of 100 mm (3 7/8"). The frame includes two sliding strips that reduce friction and facilitate sharpening. You maintain good contact with the blade and you can feel when it touches the grinding wheel. The SVP-80 Moulding Knife Attachment also allows you to sharpen profiled paint scrapers to maximum sharpness.
Easy, flexible mounting
The SVP-80 Moulding Knife Attachment has a steel plate with a magnetic insert with a number of holes. You can easily see which holes correspond to the holes in your moulding knife and insert the clamping pins supplied into the corresponding holes on the magnet. This allows you to easily and freely mount your various moulding knives for steady sharpening.
CHF 216.00
The SVP-80 Moulding Knife Attachment flat-grinds all types of moulding knives, with 24, 30, 36 and 38 mm spacing between guide holes. This jig is easy to use and the lumber gets a smooth surface with sharp blades. You can also sharpen profiled paint scrapers to maximum sharpness.
  • Sharpens moulding knives with different profile shapes.
  • Easy to set up and use.
  • Patented design supports an even, flat grind along the moulding knife.
  • Can also be used for profiled paint scrapers.
1.35 kg
Gray/black
Precision-cast zinc, stainless steel, black composite
Extra US-105 Universal Support
