Tormek T-1 Morakniv 1891
This machine is a design collaboration between the Swedish brands Tormek and Morakniv. With a collective history of over 150 years of making knives, and sharpening them, this machine becomes a tribute to the Swedish quality manufacturing and design tradition. The machine handle is made out of Swedish birch, just as the classic Morakniv handles. It has also gotten the same deep red color, a secret Morakniv recipe. To eternalize the collaboration, the solid zinc housing in Linen White is stamped with the logo of both brands. We hope you’ll enjoy this all-Swedish machine with the heritage it carries for many years to come. Oh, and enjoy your sharp knives, à la minute!
- Powder-coated cast-zinc housing in Linen White, stamped with the collab logo.
- Quiet operation at 45 dB.
- Solid birch handle in the classic red stain seen in Morakniv knife handles.
- Design collaboration with Swedish knife manufacturer Morakniv.
Linen White
Precision-cast housing in powder-coated zinc Bottom in impact-resistant plastic Handle in solid birch stained in the classic red from Morakniv knife handles.
PW-160 Conical Composite Honing Wheel Composite, ABS plastic Ø 160 × 30 mm (6 ¼" × 1 3/16")
Unique friction reduction gear drive system with RKX18 rubber. Self-adjusting for load
Stainless steel main shaft
150 rpm. Torque 2 Nm
Single-phase, AC motor Input power: idle 60 W, max load 120 W 100-115 V / 220-240 V, 50-60 Hz Maintenance-free Quiet running, 45 dB 10,000 operating hours
- Switzerland · 230V
- Article no.: T-1 ALM/CH
