Original Grindstone
Original Grindstone
200 mm
1,297 kr
Sale price  1,297 kr Regular price
Original Grindstone
All-Round Sharpening for Professionals and Amateurs
The SG-200 Original Grindstone is the perfect all-round grindstone. The grit can be adjusted between 220 and 1000 grit with the SP-650 Stone Grader. This makes it excellent for both coarse and fine sharpening, and it easily sharpens most types of tools and steel grades.
The SG-200 Original Grindstone is supplied as standard with the Tormek T-4 Original and Tormek T-4 Bushcraft. It's also available for the Tormek T-8 Original and Tormek T-8 Custom, but with different dimensions as the SG-250 Original Grindstone.
Stay True, Stay Sharp
The TT-50 Truing Tool allows you to remove the very top layer of the grindstone to restore a perfectly round shape. When the grindstone is freshly trued, the surface is particularly aggressive and can be used for an especially aggressive sharpening. The SG-200 fits the Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier Tormek models with a grinding wheel 200 mm (7 7/8") in diameter and 40 mm (1 5/8") wide.
1,297 kr
Size
Also known as Tormek SuperGrind®, it's been developed over the years to combine efficient sharpening and a fine surface finish with a long service life. It has an adjustable characteristics equivalent to between 220 and 1000 grit.
  • All-round grindstone with an adjustable surface equivalent to approximately 220–1000 grit.
  • Can be trued with TT-50 Truing Tool.
  • Suitable for most steel grades.
  • Long service life.
2.67 kg
Gray
Aluminum oxide
