944 kr
Sale price  944 kr Regular price
Softer honing and higher polishing
If you find the PW-160 Conical Composite Honing Wheel a little too aggressive or want to achieve an even more polished bevel, you can do this by wetting the honing wheel. With the machine running, take a damp cloth or sponge and hold it lightly against the honing wheel. This gives you smoother honing and a higher degree of polish.
For the sharpest and most durable results
You use the PW-160 Conical Composite Honing Wheel after sharpening your knife on the diamond grinding wheel. Honing removes the burr created during the sharpening process and polishes the new bevel of the blade. Honing is the way you achieve razor sharpness. Plus it gives you a more durable edge.
You can also use the PW-160 Conical Composite Honing Wheel for maintenance between sharpenings, to realign the edge of a slightly blunt knife. When you're no longer achieving the same sharpness on just the honing wheel, re-sharpen the blade on the diamond grinding wheel to give it a new, even bevel. The PW-160 Conical Composite Honing Wheel is supplied as standard with the Tormek T-2 Pro Kitchen Knife Sharpener and the Tormek T-1 Kitchen Knife Sharpener.
944 kr
The PW-160 Conical Composite Honing Wheel allows you to deburr and polish the bevel at the same time. It comes with integrated polish to reduce contamination, which is suitable for clean environments. This honing wheel is angled to allow you to hone even your longest knives. The PW-160 Conical Composite Honing Wheel is specially designed for the Tormek T-2 Pro Kitchen Knife Sharpener and Tormek T-1 Kitchen Knife Sharpener.
  • Easy to mount.
  • Spare honing wheel for Tormek T-2 Pro and Tormek T-1.
  • Removes the burr and polishes the edge.
  • Integrated polishing compound supports a mirror-like finish.
  • Can be used to maintain knives between sharpenings.
310 g
Black/gray
ABS plastic, composite
