SQ-90 Tormek Square
SQ-90 Tormek Square
68 kr
Sale price  68 kr Regular price
SQ-90 Tormek Square
Don't be a Square, Use One
Making sure your setup is square and that your grindstone is true are fundamental for achieving accurate, consistent sharpening results. The SQ-90 Tormek Square provides a simple and dependable way to verify your setup before you start sharpening.
Designed for Precision
The SQ-90 Tormek Square is designed for accurate, repeatable setup work. It is fully cast in zinc for durability and dimensional stability. It features a hole for a key ring or similar attachment, making it easy to keep close at hand in the workshop. The Tormek logo is clearly marked on both sides.
The SQ-90 Tormek Square is compatible with all Tormek sharpening systems and intended for general sharpening use where precision setup and control are essential.
SQ-90 Tormek Square
68 kr
The SQ-90 Tormek Square is a precision tool for checking squareness on square edge tools and for verifying the trueness of the grindstone. It also serves as a reliable reference when setting up jigs and aligning sharpening operations, while providing a simple angle check. A handy little zinc square, to keep you square!
  • Can be used to draw a straight reference line on the grinding wheel.
  • Checks a 90° angle on chisels and other square-edge tools.
  • Angle grooves provide approximate checks at 25°, 30°, 35°, 40° and 45°.
  • Checks whether the grindstone surface is true.
61 × 40 × 6 mm
76 × 50 × 7 mm
22 g
30 g
Gray
Zinc
