200 mm
2,569 kr
Sale price  2,569 kr Regular price
Mirror Finish - Never in Vain
The SJ-200 Japanese Waterstone is designed for sharpening hand tools such as woodcarving tools, knives, scissors, plane irons and chisels, which require minimal steel removal and superior sharpness. It's perfect for both sharpening nerds who want to be able to see their own reflection in their bevels and meticulous craftspeople who want really clean cuts.
It's designed to give the tool the finest surface finish, so its abrasive power is limited and it can't be used to shape a tool. If you need to give your tool a new edge, it's best to do that on another grinding wheel first and then use your SJ-250 Japanese Waterstone to give the final finish.
The unique composition of the stone gives it an extremely long service life. You usually don't need to hone on the leather honing wheel afterwards because the SJ-200 Japanese Waterstone leaves such a fine finish.
Low maintenance, long service life
You should clean the surface of the grindstone at regular intervals to remove fine steel particles. You can do this with the fine side of the SP-650 Stone Grader, or with the coarse side of a sponge. Don't use the coarse side of the stone grader on the SJ-200 Japanese Waterstone as this will damage the grindstone.
The SG-200 Japanese Waterstone fits the Tormek T-4, Tormek T-3 and earlier Tormek models with a grinding wheel 200 mm (7 7/8") in diameter and 40 mm (1 5/8") wide. A larger version, the SJ-250 Japanese Waterstone, is also available for our Tormek T-8 Original or Custom.
2,569 kr
Size
The Japanese Waterstone is 4000 grit and provides a mirror finish. The fine surface of the grindstone polishes the edge and creates the ultimate surface finish. If you want razor sharpness, this is the grinding wheel for you!
  • Designed for a very sharp edge.
  • 4000 grit.
  • Creates a polished, mirror-like bevel.
2.57 kg
Blue
Aluminum oxide
