SVD-110 Tool Rest
SVD-110 Tool Rest
407 kr
Sale price  407 kr Regular price
SVD-110 Tool Rest
Designed for stability
Woodturning scrapers often have a fairly large angle, which can make sharpening hard to control. That's why the SVD-110 Tool Rest has a generous 90×110 mm (3 1/2" × 4 3/8") surface area, allowing you to hold the tool firmly and securely against the grinding wheel. The hole where you attach the tool rest to the universal support has a special wedge shape which increases the locking force by as much as 250% compared to a round hole. You can lock the tool rest instantly at the selected angle. This ingenious design is an original Tormek innovation commonly known as the TorLock.
Simple but versatile
The SVD-110 Tool Rest can be used both with and against the direction of rotation of the grinding wheel. It can also be positioned so that you can use the flat side of the grinding wheel when sharpening card scrapers, for example. Many hard-to-sharpen tools that don't fit in any other jig or have unusual sharpening angles can be sharpened using the SVD-110 Tool Rest, in a number of other positions with a little creativity.
SVD-110 Tool Rest
407 kr
This tool rest gives you a larger support surface from the universal support. It's ideal for sharpening various rounded scrapers for woodturning. The SVD-110 Tool Rest also works perfectly with special woodcarving tools such as hollowing tools and curved drawing knives. You can also use it for card scrapers and cutting blades for woodturning tools, spokeshave and flat-head screwdrivers.
  • Easy to set up and use.
  • Versatile settings accommodate many tool types.
  • Designed for sharpening turning scrapers and other supported tools.
280 g
Gray/black
Aluminum, black composite
