Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
539 kr
SE-77 Square Edge Jig
756 kr
AX-40 Axe Jig
475 kr
2,569 kr
RB-180 Rotating Base
628 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
