Tormek T-8 Original
Tormek T-8 Original
Scandinavia · 230V
8,565 kr
Sale price  8,565 kr Regular price
Tormek T-8 Original
Tormek T-8 Original
8,565 kr
VersionScandinavia · 230V
270 × 270 × 330 mm
393 × 296 × 383 mm
14.8 kg
18.55 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
Scandinavia · 230V
Article no.: T-8 ORIG/SCAND
Instruction Manual
View
Sign up
