With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DF-200 Diamond Wheel Fine fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
DF-250
Diamond Wheel Fine
Tormek's Diamond Wheel Fine is the ultimate all-round diamond grinding wheel, combining efficient steel removal with a smooth grinding surface. The wheel has a grit size of 600, providing effective sharpening and a smooth surface finish.
- Sharpens all types of steel and ceramic.
- Side sharpening makes it possible to create a flat bevel.
- Efficient steel removal with a smooth finish.
- Durable diamond abrasive.
- Maintains a constant shape and diameter.
5.6 kg
3.18 kg
- Safety data sheet ACC-150 EN 2024 (Opens in a new window.)
- Important information regarding diamond grinding wheels (Opens in a new window.)
- Mounting grinding wheels (Opens in a new window.)
