PA-70 Honing Compound
105 kr
Sale price  105 kr Regular price
Achieve your best honing
PA-70 Honing Compound consists of a combination of microabrasives and polishing components, and has an average grit of 3 microns. For best results, always use honing compound when honing on a leather honing wheel. One application is enough for 5 to 10 tools. The leather becomes softer and more effective every time you use the honing compound. And your tools will be sharper than ever.
How to use PA-70 Honing Compound
Apply a thin string of PA-70 Honing Compound to the leather honing wheel before starting the machine. Turn the honing wheel by hand. Start the machine and distribute the honing compound by lightly pressing the tool against the wheel. Allow the paste to penetrate the leather.
When you have a new leather honing wheel, saturate it with the light machine oil included first to give it the right texture and make it capable of absorbing the honing compound. If you work in a dry climate, after a while you might need to impregnate the honing wheel again with a few drops of oil before using the honing compound. Don't let the honing compound dry out on the leather honing wheel, apply more oil if needed.
105 kr
PA-70 Honing Compound is used together with Tormek leather honing wheels. The unique qualities of the leather in combination with the honing compound effectively remove the burr that occur during sharpening without damaging the edge. At the same time, the honing compound also polishes the bevel to its final finish.
  • Average abrasive size of 3 microns.
  • For use on all Tormek leather honing wheels.
  • Produces a fine polished finish.
  • Conditions the leather honing wheel.
  • 70 g tube.
90 g
Yellow
Aluminum oxide, Petroleum distillate, Ammonia; aluminum tube
1 × 70 g tube of PA-70 Honing Compound
