Tormek T-1 Kitchen
Zinc Gray / Switzerland · 230V
CHF 439.00
Reapris  CHF 439.00 Ordinarie pris
Tormek T-1 Kitchen
For home cooks
CHF 439.00
FärgZinc Gray
VersionSwitzerland · 230V
  • Fin diamantslipskiva.
  • Pulverbeschichtetes Zinkgussgehäuse mit Holzgriff.
  • In mehreren Farben erhältlich.
  • Tyst drift på 45 dB.
Tekniska data och detaljer
Huvudaxel i rostfritt stål
Switzerland · 230V
Article no.: T-1 ALO/CH
Switzerland · 230V
Article no.: T-1 GRA/CH
Switzerland · 230V
Article no.: T-1 BLO/CH
Switzerland · 230V
Article no.: T-1 REB/CH
Produktspecifikation
  • Width: 8" (204 mm)
  • Depth: 7 ¾" (196 mm)
  • Height: 7 ⅛" (181 mm)
Cord
  • Cord length: 5.5 ft (1.7 m)
Grinding Wheel
  • Speed: Maximum 200 rpm
  • Single-phase AC motor
  • Frequency: 50–60 Hz
Ingår i lådan
Instruction Manual
View
Sign up
Professional Sharpness
Sharpening Your Knives
