602 kr
Sale price  602 kr Regular price
Durable main shaft
As you can tell from the name, the MSK-200 Stainless Steel Shaft with EzyLock is made of stainless steel for maximum service life. You can easily mount the grinding wheel with your bare hands with the composite Tormek EzyLock, which works as both a nut and a washer. The large pitch of the left-hand nut in the composite knob causes the rotational force of the grinding wheel to tighten the nut.
Change your grinding wheel easily with EzyLock
If you need to replace your grinding wheel, turn it clockwise while holding the honing wheel with your other hand. The EzyLock nut will then automatically release. This design makes it easy to work with different grinding wheels. When mounting the grinding wheel, turn the EzyLock nut counterclockwise by hand. When you start sharpening, the nut will automatically be tightened to the correct torque.
Fits the Tormek T-4, Tormek T-3 and older models with a 200 mm (7 7/8") grinding wheel.
602 kr
Stainless steel main shaft and composite EzyLock. EzyLock ensures that the grinding wheel is securely fastened, with no risk of loosening. No tools are needed to mount or remove the grinding wheel thanks to its unique design.
  • Stainless-steel components support long-term use.
  • Replaces an old shaft and can extend the service life of the machine.
  • Easy to replace.
  • Fits Tormek T-4, Tormek T-3, Tormek 1200 and older 200 mm models.
410 g
Stainless steel, composite EzyLock
