For home cooks
- Leiser Betrieb mit 45 dB.
Hauptwelle aus Edelstahl
150 U/min. Drehmoment 2 Nm.
Produktversionen
- Article no.: T-1 REB/EUR
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
Produktspezifikation
- Width: 8" (204 mm)
- Depth: 7 ¾" (196 mm)
- Height: 7 ⅛" (181 mm)
Cord
- Cord length: 5.5 ft (1.7 m)
Grinding Wheel
- Speed: Maximum 200 rpm
- Single-phase AC motor
- Frequency: 50–60 Hz
Sign upProfessional Sharpness
Sharpening Your Knives
Composite Honing Wheel
Patented Angle Guide
