Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
539 kr
756 kr
AX-40 Vorrichtung für Äxte
475 kr
2,569 kr
RB-180 Drehscheibe
628 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
